Walter Adrian escribiste:
Achino, vos que sabes, yo no recuerdo, ¿el motor es igual a que auto Bmw ?
Acá dice que lo lleva el bmw 320d , 520d y 318d. También el Rover 75 CDT y el Rover 75 CDTi..........
de FREELANDER NADA
ESPECIFICACIONES GENERALES
BMW M47
From Wikipedia, the free encyclopedia
BMW M47 engine Manufacturer: BMW
Production 1999–2007
Predecessor BMW M41
Successor BMW N47
Class Straight-4 Diesel
Engine(s) 2.0 L (1951 cc/119 in³)
2.0 L (1995 cc/121 in³)
The BMW M47 is a diesel straight-4 engine produced from 1998 through 2007
Models Engine Displacement Power Torque Redline Year
M47D20 2.0 L (1951 cc/119 in³) 100 kW (134 hp) @ 4000 280 N·m (207 ft·lbf) @ 1750 4750 1998
85 kW (114 hp) @ 4000 265 N·m (195 ft·lbf) @ 1750 2001
M47TUD20 2.0 L (1995 cc/121 in³) 85 kW (114 hp) @ 4000 280 N·m (207 ft·lbf) @ 1750 2003
110 kW (148 hp) @ 4000 330 N·m (243 ft·lbf) @ 2000-2500 4600 2001
M47TU2D20 90 kW (121 hp) @ 4000 280 N·m (207 ft·lbf) @ 2000 2004
90 kW (121 hp) @ 4000 280 N·m (207 ft·lbf) @ 1750-2000 2005
120 kW (161 hp) @ 4000 340 N·m (251 ft·lbf) @ 2000-2750 2004
Applications:
* 1999-2004 Rover 75 CDT
* 2004-2005 Rover 75 CDTi
Contents
The original M47 engine was the 1951 cc M47D20. Bowing in 1998,
it produced 100 kW (134 hp) and 280 N·m (207 ft·lbf) in its original 320d/520d guise and 85 kW (114 hp) and 265 N·m (195 ft·lbf) in the 318d.
Applications:
* 85 kW (114 hp) and 265 N·m (195 ft·lbf)
o 1999-2001 E46 318d
* 100 kW (134 hp) and 280 N·m (207 ft·lbf)
o 1999-2001 E46 320d
o 2000-2003 E39 520d
M47TUD20
BMW 320d models built from approximately September 2001 onwards were fitted with the M47TU (standing for "Technical update"). The exact production week is not known but expect it to be after Production Week 33 of 2001 (eg. you cannot rely on a UK 51 plate registered BMW 320d to have the M47TU).
This updated engine was expanded slightly to 1995 cc, ramping up the torque. It also featured improved consumption and more boost lower down the rev range, however it added 50kg in extra weight and emissions were raised slightly. In the UK, the new engine lifted the 320d into the next highest insurance bracket and next highest band for Vehicle Excise Duty (commonly known as Road Tax).
The M47TU was also fitted with twin balancer shafts to counteract the secondary balances inherent in a diesel 4-cylinder engine. The M47TU was regarded as so good that BMW made it available in the 320Cd Coupé.
Applications:
* 85 kW (114 hp) and 280 N·m (207 ft·lbf)
o 2001-2005 E46 318d
* 110 kW (148 hp) and 330 N·m (243 ft·lbf)
o 2001-2005 E46 320d
o E83 X3 2.0d (up to end of 2006)
M47TU2D20
The engine was updated again in 2004 as the M47TU2D20. Still at 1995 cc, it produced more power across the range.
Applications:
* 90 kW (121 hp) and 280 N·m (207 ft·lbf)
o E87 118d
o E90/E91 318d
* 120 kW (161 hp) and 340 N·m (251 ft·lbf)
o E60/E61 520d
o E87 120d
o E90/E91 320d
o E83 X3 2.0d (end of 2006 onwards)
PREGUNTA: ENTONCES EL MOTOR QUE EQUIPA A LA FREE / NEW FREE TD4 EROGA 134 HP?
